I have a bad feeling the answer is get a new solenoid. It doesnt work when installed on the truck. No switching of vacuum at all. Good vacuum pump, no vacuum to the waste gate actuator at idle. I replaced all the cracked plastic hoses, and all the normal troubleshooting steps, to discover the solenoid itself wasn't working. I've had it bypassed for a couple months, but I'd like to get the system working again, so I decided to do a little trouble shooting on the bench. Heres the behavior:
18in vacuum source, solenoid works perfect.
20in vacuum source, solenoid does not work at all.
Since my vacuum pump is quite healthy and makes well over 20in of vacuum, this is the problem. I guess this means the solenoid isn't strong enough to overcome the vacuum, and I need a new solenoid.
I'm doing all this because my truck misbehaves on the interstate. Around town, having the wastegate actuator run straight to the vacuum pump is great. Nice and responsive at low throttle positions, maxes out at 11psi at full throttle up a hill. However, it runs 7-8psi at 65mph down the freeway. Not ideal, and sets code 78 every few minutes.
Unless someone informs me theres some way of supercharging the boost solenoid, I'll order a new one up, and then my truck will work just fine.
