Hydrauk
Hydrauk
Hello to All!! So here we go..1997 GMC K3500 4X4.
I decided it was time to replace the front end, WHAT A NIGHTMARE!!!! I mean really!! Ok give ya heads up, I replaced or HAD to Replace the Following...ready??..Upper and Lower Ball joints, Upper Control Arm Bushings, Inner and Outer Tie rod ends, Pitman Arm, Idler Arm, Shocks, Sway Bar bushings, Sway bar End links, Wheel bearing Hubs,Hub to steering knuckle bolts, ABS Sensors, Rotors, Calipers, All bolts that hold Hub to Rotor, Upper and Lower Shock bolts.
EVERY freaking bolt either "Snapped" Or "Stripped"...I am careful...I have a Oxy/Acy torch, Good Impact with Good Air Supply, And Good Sockets and Wrenches. Let me say "NIGHTMARE" again!! This was a New Hampshire truck that I guess was NEVER serviced. It was and still is kicking my ASS!! Put it this way...a 3/8 bolt had so much encrusted rust,....hit it good with a hammer...now your 3/8 bolt is like 5/16...UN REAL!!
So...I have got past all that rust shit. I cleaned up all rust with chipping hammer, and even painted the frame and associated areas with paint, Gloss Black. It looks good...actually happy.
Here is a weird problem.....After I pulled the Upper Control arms out, and removed those STUPID riveted...I mean Stupid "RIVETED" Ball joints, I decided to sand and paint the Control arms. So now I have these.. pretty control arms with new bushings. Great...right?
OK...these damn control arms can be installed "Either" way. YES I know about the Right and Left side. BUT since I sanded them and painted them, I know longer have markings except for the part number. I am afraid of mounting them Upside down. MUCH IMPORTANT QUESTION....When you install the arms...Part number, Down or up?? I am at a TOTAL loss.....
Having a rough day...
Cheers, and thanks in advance for any dang info...
David D.
David D.
