alli_gator
Recruit
I have one PPE Standard Xcelerator for 03-08 Ford 6.0L/6.4L Powerstroke that is in an open box. It has been sent to PPE for the latest update and is ready to install in your Powerstroke. $475.00 shipped to lower 48 states
Heres info
Features:
* Two to ten power levels each with additional horsepower and torque (see tables below)
* Read and clear Diagnostic Trouble Codes (DTC)
Application: 2003-2008 6.0/6.4L Power Stroke diesel engines
Product Description:
We knew that you were yearning for real horsepower and torque out of a hand-held programmer and we delivered with the Standard Xcelerator series!
The Standard Xcelerator series was specifically designed for 2003 through 2008 Power Stroke diesel engines and provides two to ten power levels of additional horsepower and torque and reads and clears Diagnostic Trouble Codes (DTC) through the vehicle's On-Board Diagnostic System (OBD-II).
Most importantly, all Xcelerator series programmers increase the fuel efficiency of your vehicle by 2 to 3 mpg, guaranteed!
2003-2007 6.0L Power Stroke diesel engines
Power Level HP Increase Torque Increase
1 20 37
2 40 74
3 60 111
4 80 148
5 100 185
6 120 222
7 141 260
8 161 297
9 181 334
10 215 397
2007.5-2008 6.4L Power Stroke diesel engines
1 65 120
2 115 200
Note: “Legal in California only for racing vehicles which may never be used upon a highway.”
2nd Open Box Part
Edge Evolution with gauges for 99-03 Ford Pt #15001
Never installed, just in an opened package - All contents are accounted for. Here's the details - $425 shipped
Ford Diesel New Evolution - 1999-2003 Ford 7.3L Powerstroke Evolution
User Manual
Dyno Results
FORD 7.3 POWERSTROKE 1999-2003
KEY FEATURES
• FIRST PROGRAMMER TO READ AND DISPLAY EGTs, probe included
• Provides in-cab display to monitor vital engine functions
• Additional 100 HP and 200 ft. lbs of torque
• Three power levels
• Ships with a custom designed pod
• Internet updateable (cable included)
• Displays and clear diagnostic trouble codes
• Adjustable LED backlight color
• Does 0-60 and Quarter mile performance tests with the drag strip Christmas tree lighting and reaction times
• Displays Alerts and Records such as RPM, MPH and EGT
• Datalogs vital engine information
• Simple installation
ADVANCED TUNING
• Able to adjust shift points/pressure
• Adjustable speed/rev limiter
PERFORMANCE TESTING
• 0-60 and Quarter mile performance tests with the drag strip Christmas tree lighting and reaction times
DATA STREAM
• Records 5 parameters for up to 60 seconds
PIDS
The Evolution allows the user to view up to 4 PIDs at one time. There are 11 different PIDs to choose from. Below is a list and description of each:
• RPM (revolutions per minute) – Engine speed.
• MPH (miles per hour) – Note: Dash display may be +/-3 MPH off from the digital display due to mechanical differences in the spring, etc. used to control the gauge.
• BST (Boost Pressure) - PSI
• EGT (Exhaust Gas Temp) – Degrees F.
• EOT (Engine oil temperature) – Degrees F.
• TFT (Transmission fluid temperature) – Degrees F. (Automatic Trans ONLY. If you have a manual trans, the value displayed will be incorrect)
• IAT (Intake air temperature) – Degrees F.
• BARO (Barometric pressure) – PSI
• BAT (Battery voltage)
• DTC (Diagnostic trouble code count)
The following power gains are representative of an actual test vehicle. These gains were measured on a SuperFlow Dyno at an altitude of 4400 ft above sea level, and represent power delivered to the rear wheels of the test truck. The only modification made to the test truck was the addition of the Edge Evolution module. Power gains may vary based on vehicle and geographical location.
Level 1: 60 Horsepower - 100 Foot Pounds of Torque
Level 2: 80 Horsepower - 140 Foot Pounds of Torque
Level 3: 100 Horsepower - 200 Foot Pounds of Torque
Have an old Evolution? Do you want to upgrade? Call Edge's tech support to upgrade at a discounted price.
Not legal for sale or use in California on pollution-controlled motor vehicles.
CAUTION!
Your Evolution programmer has the ability to remove/adjust your vehicle’s factory speed limiter. Removal/adjustment of the factory speed limiter is intended for use at a closed circuit, legally sanctioned racing environment. Even if racing in a legally sanctioned racing environment, it is your responsibility to ensure your tires and other vehicle components are rated to travel at increased speeds with the speed limiter removed/adjusted. If you remove/adjust the speed limiter during highway driving, it is your responsibility to obey all driving laws, including adhering to posted speed limits. Removing/adjusting the speed limiter for purposes inconsistent with the product's intended function, as stated herein, is a violation of the product’s intended use and invalidates the product's warranty. Edge Products is not responsible for, or liable for the consequences of improper product use.
Heres info
Features:
1 20 37
2 40 74
3 60 111
4 80 148
5 100 185
6 120 222
7 141 260
8 161 297
9 181 334
10 215 397
1 65 120
2 115 200
2nd Open Box Part
User Manual
Dyno Results
KEY FEATURES
ADVANCED TUNING
PERFORMANCE TESTING
DATA STREAM
PIDS
CAUTION!
