Turbo band clamp
packratt
Active Member
near Richmond, VA
Does anyone know the NAPA part number for the V-band clamp for the turbo to down pipe?
Either part number or correct diameter. I bought one to match the downpipe and it was too small for the turbo. I don't want to measure the one on the truck because it may not be the correct one, it doesn't seem to hold the down pipe tight and the joint leaks.
I got my replacement from the dealer.
My old one does not show a size but is labeled as follows:
R.G. Ray Corp 15671559
There is a 72 on the end but that bears no real relation to the diameter of the clamp. If I squeeze it approximately to the clamped size I get: 3 1/2" diameter to the outside of the V and 3 1/4" to the inside of the V if that makes any sense.
cheers
Nobby
