Truck project
Truck project
Nm
Does anyone know if the first generation HD3500GM dually was offered with a Dana80 or other rear diff that had E-drum parking brake and brake rotors all in the same axle ,19.5 wheels, 7.25x10 lug pattern and not the later metric lug pattern? Part stores tell GM did so.lf so l need an assembly number or vin# would be helpful to locate a complete axle.
Thanks,
Pat
What year?
I have a 95 with 19.5 wheels and tires but my parking break is on the back end of the trans.
I have been told only the rear is 10 lug. The front is 5 lug. I have not verified this. Mine has wheel simulators.
I do have 4 wheel disc brakes.
All 3500hd's had the parking brake on the back of the trans, it was a requirement for medium duty trucks to have one there iirc. Have you tried gmt455.com for info?
What year?
I built an old truck on a later chassis 12valve Cummins, 10spd fuller trans now looking for rear axle with that lug pattern and E-brake .Part stores tell me rotor/drum assembly is available 1995-2002 7.25×10 lug pattern. Maybe not true but thanks for your reply. Truckproject
