Yachtcare
Recruit
- Messages
- 173
- Reaction score
- 2
repairs.
How tuff is it to get them bled of air? Just keep it cranking til it fires? or is there a short cut, or something else that should be checked?
Truck is in the hands of a diesel "mechanic". When I happened by this afternoon to check on progress they were trying to get it started, had the batteries run low but put it on the start/boost to crank. While I was there, we had fuel to the FFM, finally got it to the return line at the front of the IP, but none at the injectors.
I had to stop him when he started trying a gasoline soaked rag over the intake, and then broke out the can of ether.
Things I checked. Function on FSO solenoid, connections on both ends of FSD harness, fuses under dash, lift pump operating, plenty of pressure and no air there, all harness connections appear to be plugged in.
The other repairs were for what turned out to be a broken spring on #3 exhaust valve. (never had a cylinder imbalance code) Both heads were pulled, checked, cleaned up, new glows, and injectors, and a new temp sender for good measure.
I want to get over there when he gets in at 9 am, with some more advice (unwanted by him, to be sure, but) I cant stand by and watch him thrash and trash my engine with ether, either. In his defense, he appears knowledgeable, and works on heavy and medium Diesels, but the 6.5 is obviously a bit of a mystery to him.
Thanks for any pointers.
YC.......
YC.......
