matuva
Tropical 6.5er
Hi all,
here are torque specs I gathered. May I ask you to have a look and confirm I collected well, especially on the "1 pass" specs? Looks something is odd about the 506 specs.
Main cap bolts:
1988-1996: blocks 929, 599, 141
1 pass
• Ext (12 mm bolt)-- 100 ft/lbf
• Int (12 mm bolt)-- 110 ft/lbf
Or 2 passes
• First--55 ft/lbf inner, 48 ft/lb outer
• Second--55 ft/lbf inner, 48 ft/lb outer
• Last--1/4 Turn or 90* More
1997-1999: Block 506
1 pass
• Ext (10 mm bolt)-- 30 ft/lbf
Or 2 passes, 12 mm bolts inner & outer
Connecting rod: 48 ft/lb
Main cap bolts:
1 pass
Or 2 passes
1 pass
