Timing chain replacement
Michaeljp86
EVIL GENIUS
MICHIGAN
I need to change the water pump on my truck, Edzzed said I should change the timing chain too. Do I just need to replace the chain or should I buy the whole set of new chain and sprockets?
you don't have to change the timing chain, It is only a suggestion since you will be going into that part of the engine. I have heard that with 100,000 miles or more it's always a good idea to change both the timing chain and sprockets as sprockets do wear over time.
I dont want to have any trouble with it so if its something that could cause me greif Id rather fix it now.
I think Missy posted before that she has just replaced the chain.
I know with regular roller chain a sprocket will outlast several chains.
Also called a duplex chain. Use to be you could find a USA made set with sprockets & chain for not a lot more than just a chain. Can't say for sure, but have heard Cloyes are now made in China. Its really no problem just replacing the chain and keeping the factory sprockets. Finding a USA made chain might be a challenge. I actually had a conversation with Bill Heath about cam drives a while back. He says he runs a used chain & sprockets on all his engines, says there is absolutely no reason to change the chain. He has built a lot more 6.5s than I ever will, so I have no reason to doubt him. But when I built my engine, I found a new USA made Cloyes timing set, so that is what is in my 6.5.
i could of saved a few bucks if i had just replaced the chain. sprockets were good.
It's either stretched \ worn or not. Check it and see. I don't put new chains on worn sprockets personally, but that's just me.
