Truckie117
1. Describe the problem you are having in detail:
What happens is as i accelerate truck goes through gears fine but once past 45 truck wants to go faster and i am hardly pressing pedal. I can get up to 65 and when i want to ease off the throttle I have no room to back off to go slower it just drops to idle causing bucking if i step back on pedal to keep up my speed. I never had this problem running on diesel or veg. I have a totally separate fuel system and filters for veg plus separate returns. Since this is my first fly by wire rig it's a mystery to me. New water temp sensors.
Thanks
2. Year of truck/engine. 1999 chevy suburban K2500
3. Odometer reading (indicate miles or kilometers).173,000
4. Indicate the model number on the Injection pump (starts DS4 or DB2.).Unknown was replaced under warranty 37253
5. Indicate if you know if it’s a 2500
6. Do you have an EGR on the engine? VIN F
7. Air Filter condition (visual check).CLean
8. Fuel filter condition (freshly changed, mileage since changed). Changed recently
9. Location of PMD/FSD? New model behind front bumper
9a. If remote mounted, describe wiring harness (homemade or purchased from which vendor). Kennedy harness
9b. Indicate the location and condition of the FSD/IP grounding wire. On pump
10. Outside Temperature (C or F). _45f____ °
11. Service Engine Light while running?- off
11a. Service Engine light does glow during start/cranking/bulb check: Yes
12.Have you scanned for engine codes? Yes no codes
12a. List exact results on engine codes.
13. Condition of Battery terminals (removed, cleaned and tightened). Yes clean and tight bolt and nut config.
14. Known condition and age of Batteries. Less than yr.
14a. Are batteries a matched set of same age? Yes
15. Condition of Major Grounds (removed, cleaned and tightened) Have to check
16. Does engine crank, or "turn over"? yes
16a. Does engine start and run? yes
17. If engine does not start- Crack injector line: do you have fuel? Yes/No
18. Does your Wait To Start light come on? yes
18a.Number of seconds WTS light is lit. 30 seconds but if cold will come on and off a few times
19. Engine Cranking speed (if you have an accurate tachometer).
20. Are you experiencing Stalling? No
20a. Describe the event (upon driving down the road
20b. Do you notice loss of dash or instruments? NO
21. Check turbo inlet and air filter for obstructions. Yes no objects
22. In a no-hot start, pour a bottle of room-temp water on the injection pump. Does it start now?
23. Lift pump test - Describe results. Pump is new and comes on and you have fuel at bleed off
24. Upon cold start, does the radiator hose get hard quickly? Have to check
25. Upon cold start, do you have excessive white smoke? No
26. Do you have excessive cranking time before the engine starts? NO
27. Have you used the block heater? Does it affect engine starting? (only try for starting problems).
28. Are all glow plugs in proper working order? New replaced last yr.
29. During hard acceleration, do you have excessive black smoke? Sometimes
30. Do you have any unusual exhaust smoke issues?
31. Turbo check out - Pass/Fail
32. Indicate fuel that you are using: #2 Diesel
32a. If running Veggie Oil fuel setup, indicate details of your conversion (homemade or packaged system). Packaged frybrid system installed by me.
33. Are you using any fuel additives? If so, please list. stanadyne
34. Upon unscrewing fuel cap, do you have a large vacuum formed in the tank? No
35. Do you have any service history available that might pertain to the problem you are having? NO
36. Please indicate any modifications to the vehicle that might help us diagnose better.
Just the remote pmd and Veggie system
:mad2:
Thanks
:mad2:
