Thread size Nut
Gunar
Chemnitz/Saxony/Germany
Hello friends,.
can someone please tell me what inside thread size the Nut of the wheel brake cylinder by an ´ 95 Tahoe diesel had..?
9/16´´ have I on the outer Site..?Could it inner be 1 / 2´´..?
Thank you in advance....
Gunar
Hi Alaska;)
this what i mean is the rear Drumbrake...
I need the inside Diameter of the Thread....outer i must take a 9/16´´Tool to open it....what is the inner by the Brake Cylinders..?
Greats
Sorry, I was looking at the 4 bolts that hold the brake backing plate to the axle tube.
So what you want to know is the thread size for the brake line nut, which I do not know. It uses an inverted flare
Gunar, the information I gave you is for bolt thread diameters, not brake line flare nuts.
