Yachtcare
Recruit
- Messages
- 173
- Reaction score
- 2
I have a good running 6.2 "J" code motor. Was installing into my '70 GMC project(already sitting on the frame with 700r4 attached). The recent continuing problems with the old 6.5 in the dually (at over 260K, estimated) has me thinking a swap might be a good idea.
The 4l80e seems to be holding it's own after replacing all the electronics in the pan.
If I get a pedal and throttle cable from a '93, and a Jake's controller for the 4l80e. Turn up the fuel on the J code pump, and limit the boost to 10 psi, am I good to go? I got a spare set of heads from a parts 6.5 to swap the injectors into, as I would want a new head set in there anyway.
May need a new set of injector lines?
TIA for your thoughts.
