6.5coalroller
Low coolant light came on after school yesterday. Didnt think anything about it jus topped it off, but yesterday night I was wiring up some chicken lights and noticed a big puddle of antifreeze at the back of the motor. Started looking around with the light and found that my lower radiator hose didnt have a clamp so we put one on it and I figured that would be the end of it. Today drove around and while I was dumping some wagons I noticed it was still leaking worse when it's running of course but doesn't stop after it's shut off. Leaks down on the oil filter and front drive shaft. Jacked it up and got the light and put the pressure tester on it pumped it up around 15 pounds. Then a couple streams came out looked all around cant seem to find a spot on the water pump leaking unless it's running to the back but i figured if it was the calprit it would leak down in the front. Thermostat housing and the ports on the back of the heads looked fine. Replaced the blocker heater a while back it started leaking but its dry too. Radiator hose looked good also. I finally could see some coming from the drivers side head so i'd think it's jus an external leak still runs and drives good only a lil smoke on start up jus lyk it always has. No water in the oil. I replaced the head gaskets about 2000 miles ago and had no probs til now put in arp head studs too. Drivers side was a lil more of a challenge tho tryin to hold everything in place while in the truck. Maybe I damaged the gasket but I figured it would have started leaking before now. Haven't had any leaks for a long while any others ways to make sure thats what it is?
