iamdave0887
Here Comes Chaos.....
Didn't write much about this swap here. Didn't really have the time.
This pictures a few weeks old. I've since touched up the lower intake, since it had to be removed.
Oh. I found the remaining piece of lifter retainer from my other thread. It was sitting inside the oil pump pickup and fell out when the pump was removed to change the rear main seal. Talk about lucky. Thankfully there's a screen in the oil pump pickup. I'd hate to think what would've happened if there was no screen
The old rear main didn't exist. Sounds impossible right? There was no seal in the groove when i took the main cap down, and it wasn't on the crank or on the floor, which both amazed and scared me at the same time. There was rust on the crank where the seal normally rides, so it was missing for a while. That was cleaned with a bit of 240 grit emery paper.
Here's the new one going in. Seals more or less idiot proof if you know how to read. The outside lip of the seal that seals dirt out says "outside" on it. Make sure to offset the seal and use some form of sealant on the two edges where the two pieces of the seal meet.
Going by the 1/2 a main bearing i saw this engine has 20K tops. That bearing wasn't even fully worn in through it's new coating yet.
Rear main sits in the groove furthest from the bearing shell. The first groove is basically an oil slinger.
So far i've hit a max of roughly 3 lbs of boost. I haven't taken it very far, just a few blocks up. I'm slowly taking it further and further from home. The 3.08s really keep both the RPM and the boost down. Short of hammering the life out of the pedal it really doesn't build much boost, but only smokes if the RPM is too low and my foot is too far into the pedal. Max EGTs i've seen so far is ~600*F pre-turbo. The turbine housing is so huge that it takes a lot of exhaust flow to spin that charger up.
It's not as laggy as people have said but that could be because the truck isn't that heavy and it's a stick, versus a 1 ton automatic truck. It does accelerate better as i find myself getting into top gear much quicker.
