Acesneights1
Hope I'm not using up my full nickel but again was inNY working on a few 6.5s for a buddy. This is a differnt truck than I posted about. This beauty is also a 94 but c3500. He said truck got shut off and when his guys went to restart is it would not start. Nothing. He had a local guy look at it and diagnosos the IP dead. He changed the IP with a reman and still could not get fuel from Injectors. I checked for fuel from Lift pump. No problem right to IP inlet. I then decided to scan for stored codes before I went any further. Got an error message invalid something with PCM. I'm thinking OK this is not good. I checked my laptop on my own 95. No problem So long story short the fuse was blow for the PCM Put new fuse in and got fuel right away and truck started right up. I pulled up the TDCO with GMTDScan and it read -1.58. This to me seemed fine for a work truck so I said it's good to go. BUT my question is did I read the actual TDCO or was that stored TDCO and the pump was actually running something different ? Truck sounded real nice and seems to run fine other than slight stumble which I attributed to air since it had not been properly run out yet. Did I check the TDCO right or should I have done something differently ?
