The FSM's are fraught with unpardonable errors - certainly not the least of which concerns the 4L80E TCC solenoid dc resistance value: indicated value is 20-40ohms - real-life works-fine-lasts-a-long-time value = 10-15ohms - read and heed - also, now would be prime time to correct your books'n'charts, kiddies
Now, since you've rattled my cage, and as long as I'm on this kick, a word or several vis a vis the differences in lockup function between the 4L60E and the 4L80E:
4L60E TCC is direct lockup, where +12v is placed on the TCC solenoid to apply the TC clutch for hard lockup - the TCC solenoid is higher impedance at 20-40ohms so as not to overheat and self-destruct with constant applied power - not much torque is being applied thru the hollow input shaft, so this method is entirely functional in the wimpy 4L60E
4L80E TCC is soft-apply by modulation of the TCC solenoid according to torque requirement, which means the TCC is never fully applied - the TCC solenoid is lower dc resistance to achieve quicker response with the effectively lower voltages applied via the Pulse Width Modulation scheme - PCM applies a fixed frequency, varying the width of the pulses according to torque requirements - narrow pulses = low averaged voltage, TCC is lighty applied - wide pulses = higher averaged voltage, TCC is more firmly applied - there is no hard lockup due to large amounts of torque that can be applied to the hollow input shaft - the 4L80E hollow input shafts have a history of breakage in 3500-series wrecker and dump-truck service, thus the soft-apply scheme - the direct dc solenoids are 20-40ohms - the modulated solenoids are ~10-15ohms.
So, after that long slow curve, now for the quick pitch - read and heed, kiddies: there are several hard-lockup schemes available, whereby a simple switch applies direct battery power to the low-resistance PWM solenoid - not good, as the resistance is too low for sustained constant +12v service, overheating the solenoid coil, and hard-apply increases probability of input shaft failure - while there has been some success in using the schemes, you should still be aware of the imminent danger and probability of failure
Basically, by improving the venerable T400 HD 3sp turbohydramatic trans with overdrive and a lockup convertor, engineering created a fatal error by boring several holes (hydraulic fluid passages) in the input shaft in that bad boy - hard evidence of that error is: soft-applied TCC unlocks anytime the driver eases up on the go pedal, any speed, any load
That's my story, and I'm stickin' to it.......................
