bmxdkj
Question for anyone with a 3500HD truck and tranny knowledge.
I own a 1999 Chev 3500 HD, 4L80, 19.5 tires, and a 5.13 gear. At 65 mph I'm running around 2500 RPM. Pretty high I think. The TCC doesn't seem to be locking up to me, however I dropped it off at a tranny shop and the guys said it was reading it was locking up on the scanner. For some reason it just seems like the RPM's are way to high. However, I am aware the truck has very low gears, so if thats the case and how it is supposed to be, then I'm fine with it. But if it's off then I'd like to figure out whats wrong. There are no codes truck runs great etc. If the TCC isn't locking up, what should I check. I know its a long shot. I checked the FAQ's and it said the engine temp, brake switch, and speed. The truck warms right up to where it belongs (195 or so), obviously I'm getting to speed and the truck's brake lights are working. Also I've heard about PWM's in these transmissions??? Any input is appreciated. Even a point in the right direction in what to check is appreciated.
Also, this tranny shifts perfectly, no shudders, slips, grinds, burps nothing, shifts like its brand new. The truck also is far from abused and for a landscape construction truck it see's a pretty easy life. Thanks again!
