Warning, this is going to be long, but I think the chronology of events is important.
I have owned my ‘98 K2500 for fifteen years. Aside from one PMD failure (long ago relocated), and a couple of lift pumps, it’s been the paragon of reliability. My background, ASE Máster Tech, 40 years.
This summer I had the truck painted. While the bed was off, I thought I’d replace the fuel filter sock in the tank, with a genuine GM part. Got the truck put back together, and it ran like crap under heavy load. I assumed the injection pump had finally done its last, as it had presented symptoms about a year prior of getting ready to go. I had purchased one last year in anticipation of needing it, so I went on and swapped it out, a reman done by Cardone. Also did a new set of Bosch injectors, and Tygon return lines. No improvement. I felt certain I had a fuel delivery issue, so I pulled the bed back off, pulled the sender, and discovered the GM sock had collapsed. I threw it away, with a plan to install an aftermarket spin on filter before the lift pump.
Now, the fuel system seems to be sucking air. The truck stalls out after a short drive. If I jump the lift pump relay and crack the bleed on the FFM, I get air, then fuel. The return lines have bubbles.
I pressurized the fuel system via the tire valve in a fuel cap, and heard air escaping from atop the tank. Bed back off, I found a pinhole in the vent pipe that runs from the top of the sender to the fuel filler neck. I cleaned it up and soldered it closed. I also added a sealant around the sender lock ring, as it had from the factory. No help, same problem.
The steel lines running forward from the tank are not corroded, and seem in great shape. Pressurizing the tank produced no fuel leaks. I’ve also replaced the rubber line from FFM to injection pump, with a GM part. No visible fuel leaks anywhere when pressurized.
I have to get this truck running. What did I miss?
