1twisted1
So I hope you all read my build-up thread because there might be a follow up to it:nonod: ![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Stupid me wanted to see how hard it would be to turn up the IP from the top, so I opened it up to take a look. Decided that though the side would be easier and for another day so I buttoned it all up. Hit the key to pull out of the back yard and it runway on me!!:mad2::mad2::mad2::mad2::mad2::sad::sad::sad:
SO after about what seemed like 10 minutes more like 1 maybe 2 of it running full out & blowing enough black smoke to black out the sun as I was trying everything to shut it off. It pissed most of the antifreeze out (rad cap just happen to be off ) Blew what look to be the rear seal from the HV pump pushing like 90 psi & then it just shuts off.
No knocking, banging or squealing. Well it took me about 2 hrs before I could go back outside to look over the damage and to my surprise I bumped the starter and it turned over. Any ideas????? I'm afraid to try and start it again. I mean the things got to be toast right? Lesson Learned: IF YOU HAVE A MECHANICAL IP INSTALL A MANUAL FUEL SHUT OFF SWITCH SOMEWHERE !!!!!!!because this will be the quickest way to shut it down if it malfunctions or you screw up!!! That little part will give you a lot of piece of mind..
