BigBlueChevy
Compression Ignition Addict
ok so its not a GM big block... or a small block... or hell even a 4 banger... but it is gas and I really see know where else to put this.
We have an MTD yard machine 10hp 2 stage snow blower with electric start(plug in) The damn thing refuses to start. Not even a sniff of ether is waking it up. Diagnosed it the best I could on a what I figured made sence since gas isn't my thing.
-fuel isn't the problem. I've got fuel in the tank(fresh), full present in the carb. and the primer is working. 5 seconds of cranking has the spark plug bottom wet with fuel.
I pulled the spark plug and pressed it against the frame over the bore to try and get it to spark. Nothing. Tried a different spark plug, nothing. Tried cleaning the gap to clean it up a little, no difference.
I hate gassers. Is there something I'm missing? Why can't it all just auto-ignite like a diesel?
