OrionThade
Hey all,
So I'm in the process of replacing the entire front end steering and suspension. So far everything has gone fairly smoothly. I've only run into one snag that I'm not sure how to fix.
The driver side torsion bar is rusted into the key. I had much the same problem with the passenger side, but was able to force it loose by placing a bottle jack beween the tranny crossmember and the torsion bar cross member. No such luck on the the driver side.
I don't have an acetelyne or oxy-propane torch, just a regular propane that I have used to heat the key up. I've read that the torsion bars don't like a lot of heat, so I have been careful to localize the heat as much as I can.
Still no go.
My next thought is the place a solid round object in the key window in the cross member and give it a few solid whacks with a dead blow hammer. Other than than, does anyone have any suggestions?
Thanks a bunch.
Still no go.
Thanks a bunch.
