iamdave0887
Here Comes Chaos.....
hey guys.
I hope this thread doesn't turn out as grim as i'm feeling right now. This thread will decide the blazer's fate i think.
Long story short i was coming up a big hill and was into the pedal a tad. All gauges were normal. Engine was at operating temp below the 200* mark on the temp gauge. Oil was just over 40 psi. Just over 1/2 throttle or so when i heard this awful noise. It sounded like a knock so i pull over but can't get out and check on the busy road. Flip my hazard lights on and see if the truck will move. It drives like it always has, trans shifts fine, clutch engages and disengages fine with no slip when i stomped the go pedal a few times. It has the same power it's always had. No more visible smoke than normal(a small puff when i take off in 1st gear and if i shift too soon i get a little smoke in 2nd gear until the engine isn't lugging anymore)
So i pull into the driveway thinking all these terrible thoughts about my engine's health. I roll over the block that's my "emergency brake" make sure the truck is in neutral, let off the brake and the truck doesn't roll, pop the hood and get out. Then the damn truck starts rolling backwards on me and fast. It slammed right into the old portable basketball hoop at the bottom of the driveway. Scared the life out of me watching my truck roll away. No visible body damage to the truck so it must've hit the bumper trim. So now i'm just pissed off. I get in the truck shove it in 1st gear and pop the clutch spinning both tires in the process of going back up my driveway.
Anyways, I checked the balancer , not loose at all and all rubber seems to be intact. Same goes for the crank pulley, it''s fine. It's got a metal to metal sounding tap that i can't place very well other than it sounds like it's coming from the passenger side somewheres. I pulled off the oil cap, almost no blowby(same as always). Pulled the oil dipstick expecting to find metal, yet i didn't find anything. The oil's black as sin but no surprise there(only 1,000 miles on the oil). The tap follows engine RPM. At it's lowest point oil pressure was just over 20 at idle and when i brought the RPM up just a touch it came up to 40 lbs and went past 40 when i revved it higher.
Could it be a stuck injector? The injectors are kenny's old Tahoe injecotrs that he said had about 160K on them IIRC. I had enough energy to crack one injector line(driver's side front most), giving myself a knuckle buster in the process and the truck started to miss but the sound was still present. Tighten the line back up and the miss was gone.
If i busted the crank it would make a hell of a racket wouldn't it? If the crank was busted i wouldn't expect it to run as smooth as it always has. If i spun a rod bearing wouldn't oil pressure be low and i'd have metal in the oil correct?
Could i have a lifter plugged with crud considering how long this truck sat for.
Any idea what i could've busted?
I don't know folks, my heart just feel torn out right now. I put so much into this truck, i'd hate to see it go like this.....:sad:
- Dave
- Dave
