Koots
Don't Mind Me
So about a month ago my truck decided to keep stalling out til i drained the batteries. Tried to go back the next day and fried the fusible links...fast forward 2 weeks later and i finally got the truck into my shop.
Replaced the fusible links, decided to change my injectors and return lines at the same time with new Stanadyne units and replaced the mechanical lift pump (with another one). After all that was done i still couldn't get the thing to start and i ended up frying my starter up.
Finally got another starter (GR 28MT version) and it just can't seem to spin the motor well enough, even with a brand new 1/0 cable from the battery to starter, new fusible links, 1/0 cables all around (still has stock sized battery grounds though) and checked and rechecked all connections, pulled the starter a few times to make sure everything was tight and working as it should. Seemed to be fine. It's a remaned SR577X Bosch unit, just for reference sake
When i'm cranking it does it considerably slow and i can see that it's causing my dome lights to dim very hard while it's cycling. It seems to be spinning unevenly too, like there is a slight lope to it.
Bottom line: I hate this thing right now LOL I do love it but i never expected to have this much trouble with it. I guess that's what i get for bragging that the truck sat for 5 years and besides replacing the glow plugs, i didn't have to do anything to the motor LOL.
