starter/AC relays 95 through 98
jrsavoie
Recruit
Rural Clifton, Illinois
Are the starter and A/C relays the same 95 thru 98?
I have the original relays in all 3 vehicles. With the exception of one A/C relay that was swapped with the starter relay and replaced with a made in China piece.
All of the vehicles are over 200,000 miles. I'm thinking it would be a good idea to replace all the starter relays with a good quality replacement.
Are these best bought at the dealer?
Where is the best place to buy a quality replacement relay? Any part numbers or links would be appreciated.
Thanks
Still looking also for the relay socket.
Is it posible to use the spot in my under hood fuse box that is empty? What does that entale? There are no prongs to plug into So I would need those parts also.
You could use the empty spot in the underhood fuse box. You'd have to get another fuse box from the junkyard and remove the connectors. Has to be almost impossible to find relays that aren't made in China.
