nobby
Old Timey Diesel Guy
Note: ***This thread has been created at the request of the original Poster in order to not mess up the intended technical content of this thread http://www.thetruckstop.us/forum/showthread.php?t=21858*** -Pepperidge
If you are running 3.42 rear on a Suburban and load up regularly then the Pyro is a must in my book from a reliability standpoint. Does not take much of a sustained grade to get you fast approaching the crispy zone even with a free flowing exhaust. Not really a mod so to speak as your engine will not really be reliable with a melted piston!
Also do not really see the Fuel Pressure gauge as a necessary starting investment from a reliability standpoint. Simply regularly service your Filter and as far as the lift pump is concerned listen for the tick on start up.
Not sure if it necessarily belongs on those headings specifically but change injectors say at least before 150,000. Its been discussed before by those with high mileage units but as far as I am concerned injectors are a maintenance item on a diesel and the lighter the piston (when aluminium) the more important it becomes. Just noticed its number 9 on mod upgrades, not really a mod/upgrade.
Cheers
Nobby
Cheers
Nobby
