Speedometer not working
Tony Cartaginese
Slidell, La
94 Silverado 1500 2wd Just restoted truck and put back together. Replaced speed sensor in tranny, also took out vssb sensor & checked for corrosion and loose connections but all is clean and good. Any suggestions?
Is there continuity all the way through on the wires ?
when You are talking about restoration, was the dash taken apart ? might be a bad connection in the dash.
If it's shifting, the speed sensor and vssb are working. All that leaves is the wiring between the cluster and vssb, or a loss of power to the cluster.
