1twisted1
If you take a look at at my build up int he 6.2 section you'll see I've got the A-team all mocked up and ready to go. Now I need a little help with some things! for those of you how don't know this is a Gasser to diesel conversion so it's not like I can just put it all back where it came from.
First: which of the oil lines coming out for the block is the high pressure side see pic (top/front or bottom/rear)
Second: I have been told that I have to run the filter that was on the motor! ((see pic) is this the stock filter or is it one from a CUCV\HMMWV?)) because it is what control's the shut off of the fuel. Is this correct? Is there a way to by pass? the truck already has Duel remote filter with water separators.
Third: can anybody tell what each of the spade connectors on the pump does or control's? See pic Or what color wire get's connected to it?
And Last does anybody have a motor wiring diagram for a 80ish 6.2
thanx in advance.
thanx in advance.
