Wreckinball67
- Messages
- 130
- Reaction score
- 301
Hello all,
Need advice with emissions. My 98 K1500 has less than 1000 miles since I installed a new GEP motor last year. Runs great but had to have it smogged and I was told the OBDII readiness monitors were "not ready". Apparently there are not enough drive cycles. I'm having difficulty finding information about this particular vehicle. I have tried doing some drive cycles as seen on YouTube but, of course they are generic. I have a Bluetooth scan device which shows codes and the like. SES light is off but, while driving I keep getting a pending code for the EGR saying flow is low.
EGR is new when motor was installed as well as the EGR solenoid, vacuum pump. Intake was completely cleaned with new motor.
I did have a "misfire" monitor that needed to be reset, which it finally did.
Every time I clear the pending codes it seems like I have to start over. The "misfire" monitor will again say "not ready". It eventually completes its test but, by that time the pending EGR code is back.
Not sure if the drive cycles are taking place if there are pending codes. Also, if I clear the pending codes am I also deleting the accumulated drive cycles?
