As soon as it stops raining i will get under her and check wires and i will dive down the street to see if its 2nd gear. The problems started after filter change but it was I'd say a good couple of weeks after. No check engine lights. What i did notice tho is the the tranny mount on the cross member is worn out and loose.Stuck in 3rd is odd. The trans has a 2nd gear ‘limp mode’ that is the normal default when something goes wrong. Are you sure it is 3rd not 2nd?
Wires pinched by trans pan is a common cause after a filter change. Did problems start after or before filter change?
Not being able to manually shift doesn’t fit limp mode however. Tps wouldn’t limit manual shifting either.
Codes....
Do NOT just get rid of trans until new one is in and working because of year changes
