Welcome to
The Truck Stop, iluvdrt95! This here is the best place on the web for you to learn about your truck and meet up with the best people around (some of whom you've already been talking to ... :thumbsup
1] Help us out a bit, before we start helping you; fill out your signature with details of your truck and what you've done to it so far. Click on the signature link (in
my signature) and it will take you to yours. We need to know what modifications you have already made - it helps with diagnosis.
2] When you have a minute, click on the Diagnostic Checklist in my signature; when it comes up, highlight and copy it, then come back to this thread and paste it into a new post. Fill in as many details as you can, answer as many questions as you know how to... it will let us see and hear through your eyes. Diagnosing truck problems over the internet requires some really good information.
3] The 6.5 Technical Library in my signature has some great information in it; you might want to read through there when you get the chance, so you can learn more about your truck.
Now - thoughts for you to consider...
- Buddy is right - the code you got (DTC 78) just means 'boost out of range' ... it means your computer is calling for x amount of boost and your engine is actually getting a different amount - more or less - than was requested.
- AK and leo (NVW) are usually right, too ... your symptoms all sound like too little boost, probably caused by a cracked line to the wastegate controller at your turbo.
- your wastegate is normally open ... meaning you get very little boost; when yout computer calls for more, the solenoid you replaced OPENS, letting vacuum get through from your vac pump to the wastegate, which pulls the wastegate CLOSED. A turbo with a closed wastegate develops boost pressure.
If the vac line is cracked, it can't get a complete vac circuit to the wastegate, meaning the gate stays open a crack... too little boost is then developed.
- You need to invest in a cheapie vacuum gauge - they're like $10-15 ... you should normally get ~20" vac at the pump, and no less than 15-18" at the wastegate actuator. With a gauge, you can trace your vac circuit and see where the problem really is.
Jim
