Norwegiandiesel
Hi guys.
When first assembled Service manual says the main bearings are selective fit. What do you do when you replace main bearings? When explained in the service manual it also seems they mixed different sizes upper and lower halves of bearings in the same bearng , sounds insane to me? Do you do it like this or do you put in standard size bearings if no machining has been done to the crank or web?
Thanks
Thanks
