I also put the second heater in the other bank's center freeze plug & the cord fit snuggly under the starter rear brace.
Hadn't seen bk95td's custom starter brace made from a chunk of angle iron when I did mine, but will be copying his idea & making installing a similar, more rugged starter brace in the future.
My reason for putting in the second block heater at engine rebuild time was primarily for redundancy as the original heater looked fine/no significant corrosion so I reinstalled it, but figured it's so easy to put in a new one on the other bank while the engine's on the stand (& so much more difficult to put a new one in, when the engine's in the truck).
That being said, 2 heaters will heat things up notably quicker for those times when you forgot to plug it in the night before. If you pay attention to total wattages, you can size the 2 heaters so they'll still work on a common 15 amp household circuit, so you can use 2 or 3 way adapter plug & just one extension cord/outlet.
