RCpullerdude
- Messages
- 229
- Reaction score
- 3
Well, I just scanned for codes, and have a lot more than I thought, and some different ones than I thought. I have:
DTC 29 - Glow Plug Relay Fault
DTC 31 - EGR Control Pressure/Baro Sensor Circuit Low (High Vacuum)
DTC 33 - EGR Control Pressure/Baro Sensor Circuit High
DTC 36 - Injection Pulse Width Error (Time Long)
DTC 44 - EGR Pulse Width Error
DTC 49 - Service Throttle Soon Lamp Circuit Fault
DTC 57 - PCM 5 Volt Shorted
DTC 62 - Turbo Boost Sensor Circuit Low
DTC 84 - Accelerator Pedal Position Circuit Fault
Okay, what's wrong? From what I gather, there are some boost and EGR errors (low vac/bad pump maybe?), and there's a "go" pedal problem and the idiot light on the dash for it has issues, so it can't alert the driver. What else needs fixen? Truck runs great, just has more codes than the military.
Thanks.
Thanks.
