Hi guys ... I've been talking to Chris in Belgium via PM, and asked him if I could post those here so you guys could help out (since most all of you are smarter than me!
First, the checklist:
CHRISSUBURBAN’S TRUCK
MY TRUCK ; 1997 CHEVY SUBURBAN LT K1500 6.5 TD WITH 215.320 KM
THE PMD IS NEW
THE LIFT PUMP IS READY
THE 2 BATTERY IS NEW
Problem: Explain your problem in concise language (ie: Cranks but won’t fire).
_the engine turns but not start
_http://www.youtube.com/watch?v=-e_FTmzDbBc
- Year:
_1997
- Truck model and class (ie: c2500) __
K1500
- Automatic or Standard
_AUTOMATIC
- Mileage: (indicate miles or km) _
__215320
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) __
PMD
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? __
turbo diesel
- Ambient outside temp: (indicate *C or *F) _
20 C
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc)
1 diesel
- What fuel additives are you using?
0
- Where are you located? _
BELGIUM
- Air filter __
215320
- Fuel filter _
215320
- CDR Valve? _________
- Coolant – last flushed/replaced at
- Oil – synthetic/regular, changed at _
215320
- Batteries – state of charge, (matched set) replaced at
NEW 15-04-2011
- Battery cables and grounds (removed, cleaned and tightened):
YES
- Glow Plugs - how many miles on them? 25000 KM_What type? ___
- Injectors - last changed at ______
- What were you doing when it happened?
ON WAY_
- How was the truck running fine before this problem appeared?
VERY GOOD
- Has this problem ever happened before?
NEVER
- Describe any related factors that might be part of the problem.
pmd and I.P
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __
NO__ And?
Diagnostics:
1] Starting:
1a] Does the engine start?
NO
1b] Does the engine crank over? _
yes
1c] Are your batteries fully charged? _
they are new
1d] Have you removed, cleaned, and tightened all battery connections? _
yes
1e] Does your Wait to Start light come on for a time? How long? _5 second_
1f] Does your glow plug light come on? _yes_ For how long? _
5 second_
1g] Do you see smoke from the exhaust while cranking? What color?
no____
1h] Does the Service Engine Light Glow during Start/bulb check? ________
2a] Can you hear your lift pump working? _
yes_
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? _
yes
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? _
yes
2d] Loosen an injector line and crank the engine - does fuel come out? _
no__
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? _
yes_
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) _
remote mounted
3b] Condition of Extension harness (if used) Vendor or Homemade? _
vendor_
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _
all ok__
3d] PMD Make: ___________
3e] PMD Age: _
1 week_
4] Stalling Issues
4a] Do you experience stalling only when hot? _
no___________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) _
no
4c] Does pouring cool water over the IP seem to help with restarting? _
no_
4d] Is stalling momentary (engine recovers)? _________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? _______
5b] Any bubbles or oil film in coolant overflow tank? _______
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? _
no_________
5d] Excessive white smoke from exhaust on cold start? _
no________
5e] Excessive black smoke from exhaust under hard acceleration? __________
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? ___________
6c] Have you added a performance PCM (reflash) or Chip? _
no_
6d] Have you changed exhaust / downpipe / crossover? _
no_
6e] Wastegate – mechanical or vacuum (OEM)? ______________
7a] Single or dual thermostats? ____________
7b] Have you replaced them lately? Manufacturer of replacements? _
NO
7c] Have you pulled and cleaned Radiator and coolers lately? _
NO
7d] Have you replaced the fan clutch? Manufacturer of replacement? _
NO
7e] (winter) Have you tested your antifreeze? Good to what temp? _
YES_
7f] (winter) Are you using a winter grille cover? _
NO__________
HI ,
First sorry for my englis
my truck is a 6.5 TD CHEVY suburban LT K1500 de 1997 there's 215.320 KM
I leave in belgium
I use only station fuel,i make alway servicing on time.
I need your help because my truck stop directly on the way
-the lift pump is ready
-i by 2 new battery next week but not changement
-i verified all fuse it's all ok
-the PMD is new i use 2 week ago
-i make my truck's video on you tube ; http://www.youtube.com/watch?v=s8JH7-7KdrM
-today i opened my IP i remved the cover of optosensor it's full of fuel but when i oppened one injector line and crank the engine not fuel com out.
I want to know if I should change my injection pump or just my optical sensor
Let me know please. again sorry for english
