Mr. Hipster
After the epic fail of using 6.5 head gaskets on this 1st year 6.2, took my lumps installed correct +.010 Felpros w/yet another set of new head bolts. Hope I have the glow plug wires protected well enough, the vertical gage thing is to monitor blow by, reading were inconclusive. Crafted some copper tubing to equalize the water flow from back of block. Junk ran good once the air got out of there. With load, guessing about 1800 saw 5# of boost, WOT against the 13" Allison spec converter.
Test stand continues to add value to my life, one of the load runs block heater blew out, easy fix on the stand, not so much in the 4x4 truck.
