RPM Lock ?
Matt Bachand
Depends on the 6.5
Worcester, MA
I've done the high idle switch, and like the 1750 or so RPM the high mode goes into. Would be really nice if I could use this on the highway as a sort of RPM Cruise control. Any ideas? (thinking a switch is cheaper than buying a Cruise Control Switch.
On the same note, anyone have a good source for croise control switches?
ACK!! Danger, Will Robinson, Danger!!!
Please tell me you don't really want a cruise control that reverts to speed as soon as you take your foot off the brake... or at least tell me what highwways you're going to be driving on so I can stay, oh, perhaps a continent away...
Much better question, amigo...
Yeah :) I have an ABS light on that I don't care to fix, and I believe this stops cruise from working? Aces?
Might be. The PCM might consider something is not working properly and is cutting what we can call "not essentials functions".
When I was having issue using a "used but good one" PMD while excpecting the new one, I had no cruise. It came back with the new PMD.
You might want to talk with Acesandeights, he added cruise control to his truck..... with stock parts
