Here I am out on the road in my 1999 P30 chassis motor home about 1600 miles from home. http://www.thetruckstop.us/forum/showthread.php?28121-My-new-to-me-6-5-L-TD-motorhome
And made it to a Starbucks for wifi. The campground we are in doesn’t have it L
Well, here are some issues that I’m having along the way and one is causing me concern. First thing I did before leaving home was to change oil, filter, air filter, flush and changed coolant (got rid of the orange stuff). I also relocated the pmd with a Heath Diesel kit. I wanted to install an IC, but there wasn’t enough time to do all the mods (turbo rotated and heat shields modified) needed to make that happen this time, although I had all the parts required. Another thing I wanted to do to keep the heat down, was to install a water/meth kit from Snow. I ordered it 2 weeks prior to our departure date, figuring a good day or so for installation and testing. Well, they sat on the order for over a week, then when I called them to see where it was, they told me that it was to ship that day and to arrive at my house in 4-5 days. That would have worked, but it took another week and a half (I’m thinking that they really didn’t ship on the day they said because it arrived 2 days after I left) to get to my house. Another thing that I did was to add an inch and a half more insulation under the doghouse to help quiet the engine noise (you know that telltale 6.5 sound of a hog eating hickory nuts) and the sound of the fans kicking in when it heats up.
Here are the issues I’m having on the road:
1. The first thing that I noticed ( this new as I never had this happen before in the 15k miles that I’ve driven it since I bought it) was that when I would stop for a break or fuel or even for the night, is that the engine on start up, would sound and feel like it was missing and it would smoke (black) more than normal until I would get out on the road and up to speed, then it would clear out and run normal. This problem is slowly getting worse and on the last day I drove it (we are in a holding pattern because of events we are attending for a few days) a DTC showed up PO308. Misfire #8 cylinder. I cleared it and it showed up again later in that day. When I start cold it runs real ruff and smokes (mostly black) until I can get out o the road. One day I tried warming it up while parked before hitting the road and no change. I also noticed that if I try to take off right away, there is little response to the fuel pedal while in drive, unless I rev it up to clear it’s throat before taking off and even then it smokes like crazy. This issue is very troubling, being so far from home.
2. At about the 1200 mile mark of the trip, the engine just quit going down the interstate. I slipped it into neutral and it restarted and ran for about an 1/8 of a mile, then quit again. I was able to coast and get it pulled over to a safer spot to figure out what next to do. Thinking that the added heat from the extra engine bay insulation may have had something to do with it (I don‘t know why I thought that, but I was anxious), I removed the doghouse and removed the added insulation. Still no start. I didn’t think it would be the PMD, as I just took it out of the box and installed it (behind the front bumper) the day before I left. I did check the wiring harness, thinking maybe a rock kicked up and damaged it or something like that. No, that wasn’t it! I then got out the spare Heath PMD kit that I had for my K3500 (that I hadn’t installed yet) and brought with just in case. I plugged it in and it fired right up (WOW). I then plugged the installed one back in and it fired up again. Huh, that was weird! I put the cover back on and continued to our destination for the next day or so. It was about 30 more miles. After a day+ break, we were back on the road. In about 300 more miles it quit again. This time it was in a little more precarious place. I was able to get pulled over just feet before a construction zone where it narrowed to a single lane. I quickly pulled the doghouse cover and switched out PMD connections and it fired right up. I left the working PMD heatsink unit sitting by the passenger’s feet, just like we had to do on the journey home from the purchase of the new to me motor home. This is where it is staying till we get home. The engine hasn’t quit since, so I guess I’ll be trying out that super warranty that Heath has. Just a note: The newer PMD (the one that failed in just 1200 miles) is a grey one and the one that’s working right now is a black one.
So if anybody has some ideas on the engine miss/smoke thing let me know. Hopefully it’s something I can fix on the road. I’m in the Seattle area and have a car in tow and have, so I can get around to get parts. I also have some tools along, but not many. So if there’s anybody in this area that can help, I’d be grateful. I can check this site on my phone and will be to see if there are any thoughts on my issues. :???:
