L98TPI
I need to swap a TH350C (lockup converter) for a plain old TH350. It would be no big deal if it were not for the regular 350 is a short version and the C is a long tail version. I have rebuilt transmissions before, I rebuilt the TH350 20 years ago come to think of it. I do see in a book I have the the lock up related stuff is in the front of the trans and on a aux valve body, so I don't think that will be an issue. I suspect there has been changes over the years but I don't know what might keep the TH350's rear shaft from working with the TH350C's front one so I can use the short tail case. BTW that makes it the same length as a TH700R4. The TH350C is from 1983 and the TH350 from 77-78 as best as I can tell.
Any trans Guru's out there? :bow:
The Other Mark
The Other Mark
