steelydan
What causes reverse flare? I had it a few times in my '95 and twice in my '99.
(Reverse flare as I understand it is when the truck suddenly accelerates just for a second when in reverse.)
I moved the PMD off the pump today. What a PIA. Mounted it to a large piece of heat sink. Bolted the heat sink behind the license plate as others have done. Then I had reverse flare twice today...When I removed the PMD from the pump the nuts on transitors were loose so I re-torqued them. I bought a new PMD from Pennascola but just re-installed the one off the pump on the heat sink. The new one will be spare.
