11.5 mm should work. The other size was 8. something mm. There was only 2 different sizes.Thanks for the help, BK. Oh damn. I just looked at the link and they are 11.5mm diameter.
Hessain imports is half the price of mercedes sourse.
He doesn't have a web site. I posted his email address. It sometimes takes a day or 2 to get back to you but he will. Be shure to tell him Barry sent you. I told him I would blab his name on the 6.5 diesel sites. I got a word back from him on the german injector nozzles. The mfg. doesn't have any in stock at this time. If I wanted to order, I'd have to order 300.got a link for the hessians?
From what I understand about the german nozzles is that it atomizes better and are much more durable than the, made in india ,bosch nozzles. From what I read the quality of the material and the quality of the machining/workmanship all went way down after the manufacturing was moved from germany to india.It would make a different spray pattern? Or perhaps a BETTER atomization?? Do you know?
From what I've read ,bosch is not the best by a long shot anymore. They are not the worst either. I would want to try the german nozzles out before I would endorse them. I will say they look promising.
I've only used 4 different thickness shims in 12 injectors. The shims vary .05 mm in thickness. You just repeat the process untill they reach the correct popping pressure. It's good to know that the ones going in my engines are set as close as possible.
That's why I'm looking at nozzles also.
Do the bosch india rock auto ones, that way I have an idea how far off they are![]()
Matt I AM getting the pop pressure tester so I'll be sure to let you know. Matt, you just did your's with RockAuto ones didn't you? Are you just curious to see how well they are balanced?
ExactlyPurely selfish reasoning....
"that guy" on Ebay is up to $170 plus $29 shipping ........ I should have bought more sets...........
anybody got any info on the Mylex tips?
Nice thread, wish I'd thought of checking my injectors before I installed them, my local diesel guy would have tested them for free.
I bought brand new Delphi one's, so far, so good, runs smoothly, or so it seems, lol.
What is too high a pressure to start making the IP wear out faster?
