Joey D
- Messages
- 528
- Reaction score
- 8
I pulled the bed off the truck tonight, removed the sending unit, guage was all over the place and I had a leak coming from up there. The factory lines were rotten around the crimp fittings and leaking bad.
I bought the new sender and the dealer even had new lines in stock, not cheap though.
Supply line went from the tank to the lift pump and the return went to the junction point in front of the lift pump where they change to run up to the engine. I am changing those next. Nice factory looking job when I finished.
One thing I liked that GM did was to coat the top of the tank where the sender is held in with the ring was all covered in wax and once I scraped the wax of it was like brand new under it, made the job very easy.
I was debating Tims fuel line mod but decided to skip it.
