noitsnotme
- Messages
- 3
- Reaction score
- 0
Problem: Explain your problem in concise language (ie: Cranks but won’t fire). ___I replaced the starter and now no mil and no glow plug light, I unhooked batteries before changing, have done many tests, fuses, voltage at pcm, even tried new pcm even though did not believe it to be bad? AT my wits end ___here.______________________
- Year: _1994_____
- Truck model and class (ie: c2500) __2500_______
- Automatic or Standard ___Auto_______
- Mileage: (indicate miles or km) ___190000 miles______
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) ______PCM_____
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? ___p NA___________
- Ambient outside temp: (indicate *C or *F) __inside________
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) ___1______
- What fuel additives are you using? ___many________
- Where are you located? ___iowa__________
- Air filter _____?____
- Fuel filter _____500____
- CDR Valve? ___?______
- Coolant – last flushed/replaced at __?___________
- Oil – synthetic/regular, changed at __reg___3500 miles_____
- Batteries – state of charge, (matched set) replaced at ___charged__________
- Battery cables and grounds (removed, cleaned and tightened): _______yes_______
- Glow Plugs - how many miles on them? __?_______ What type? _____________
- Injectors - last changed at ____?___________
- What were you doing when it happened? ______changed starter________
- How was the truck running fine before this problem appeared? _____yes________
- Has this problem ever happened before? ____no___________________
- Describe any related factors that might be part of the problem. ______no mil and no glow plug activity________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __n__ And? ________
Diagnostics:
1] Starting:
1a] Does the engine start? ___no______
1b] Does the engine crank over? ___yes_____
1c] Are your batteries fully charged? __yes_______
1d] Have you removed, cleaned, and tightened all battery connections? ___yes_____
1e] Does your Wait to Start light come on for a time? How long? _no________
1f] Does your glow plug light come on? ___no______ For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? _____no___
2a] Can you hear your lift pump working? ____________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? _________
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___________
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) _____not sure what looks like______
3b] Condition of Extension harness (if used) Vendor or Homemade? _________
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _________
3d] PMD Make: __?_________
3e] PMD Age: ____?________
4] Stalling Issues
4a] Do you experience stalling only when hot? ____________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ______
4c] Does pouring cool water over the IP seem to help with restarting? _________
4d] Is stalling momentary (engine recovers)? _________
4e] Does SES light come on when engine hiccups? _________
4f] Does cruise control quit working when engine hiccups? ___________
4g] Does re-starting seem to reset engine, restoring cruise and power? _________
4h] Changes to dash lights or instruments during stalling events? ___________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? _______
5b] Any bubbles or oil film in coolant overflow tank? _______
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? __________
5d] Excessive white smoke from exhaust on cold start? _________
5e] Excessive black smoke from exhaust under hard acceleration? __________
6] Performance Issues
6a] Do you have gauges? ___________
6b] Maximum boost under load? ____________
6c] Have you added a performance PCM (reflash) or Chip? ______________
6d] Have you changed exhaust / downpipe / crossover? ________________
6e] Wastegate – mechanical or vacuum? ______________
7a] Single or dual thermostats? ____________
7b] Have you replaced them lately? Manufacturer of replacements? _________
7c] Have you pulled and cleaned Radiator and coolers lately? ____________
7d] Have you replaced the fan clutch? Manufacturer of replacement? ________
7e] (winter) Have you tested your antifreeze? Good to what temp? __________
7f] (winter) Are you using a winter grille cover? ___________
- Year: _1994_____
Diagnostics:
1] Starting:
3] PMD / IP Issues
4] Stalling Issues
5] Running Issues
