chessie 6.5
This may be old news, but Goodson Mfg. sells a kit to repair issues with cracks between the valves. I have used the kit on three different engines several years apart; 82,86 and 94. You remove those tiny freeze plugs on the intake side of head. There is a small drilled passage that allows water between the valves. You use the drill bit that comes with the kit to drill out the passage to get it uniform. You then use an included reamer to final size the holes. There is a holder/installer that you put a thin split brass sleeve on. Put the split 180 degrees away from crack side. coat it with Loctite and drive it in with a hammer applied to the holder/installer till installer seats. Install new freeze plugs and you are done. Kit comes with enough sleeves for three jobs, I believe. They sell the items separate if you damage or from normal wear. I have had no problems or failures with this repair. I think I paid about $159.00 for the kit 20 years ago. Well worth it with saved heads.
