iamdave0887
Here Comes Chaos.....
I had the truck up on the lift at school last Thursday, and noticed that the back of the oil pan was moist. The truck never leaves a drop of oil in the driveway.
At the recommendation of another member i cleaned out the CDR valve as i didn't have the $$ to buy a new one at the moment but the current one has less than 15K miles on it. The CDR was filthy inside and now is much cleaner.
I was told the CDR valve can crud up when changing from conventional oil to synthetic oil. I switched from Rotella T 15w-40 to Amsoil 15w-40 2-3 oil changes ago(i go 3K on a filter and 6K on an oil change). I'm due for another change now and this will be my 3rd change running amsoil. I'm going from a Wix filter to an Amsoil filter this time as well. Could the amsoil have crudded up my CDR as it was cleaning everything out?
I know with a worn out CDR you can get front and rear main seal leaks. I'm curious as to if the dirty CDR caused my leaks or if i need to swap out the rear main seal? I bought a seal, but really don't feel like dropping the trans if i really don't have to.
There oil pan wasn't dripping oil, but was slightly moist(had a shine to it).
when it started i wouldn't loose more than 1/2 a quart over 3-4K miles.
I've got to get the truck on the lift to change the oil tonight, but i'm curious if i should hold off on the oil change and do the rear main first? As of right now the truck's got 175,7xx miles on it.
thanks guys.
thanks guys.
