schiker
Do any manual truck guys have these problems?....
I get some truck hop from rear leaf springs "s" wrapping and recoil that can repeat in 3rd gear towing. Today with gooseneck and 600 lbs loaded in middle. I can also get some hop with just heavy stuff in bed of truck like several hundred pounds up to 1700 lbs +/- of landscape stuff so I don't think its a tongue weight issue. I also get something like clutch chatter launching in 2nd sometimes. I can usually corelate the launch chatter to poor fuel. If I lube it with SAE 30 ND and Stanadyne it launches smoother. It has progressively gotten worst with age. I think its the IP getting tired and not being able to precisely control the fuel metering and corrections to metering from PCM feed back at idle. I launch from idle then roll into fuel.
But this 3rd gear hop I am into the throttle and think its more spring wrap issue I can get it to stop but have to clutch and change fueling or down shift and wind it up pretty high then shift again. I am not lugging it either RPM's are 1600 at lowest more like 1700 and can do it a bit higher at bottom of 3rd gear.
Shocks are Belistiens and maybe a year or 2 old less than 40K miles iirc and the truck seems to drive ok otherwise. When I first put them on they didn't stop the launch chatter it stayed correlated to a fuel issue
What do ya'll think it is tired motor mounts, spring shackles, and or springs general aging mostly that allows the motor to move more and gives the PCM and IP a fit trying to compensate and adjust to stay smooth??? (has not been beaten but tows heavy occasionally more so early in life a 5'er)
Kinda related every once in a while I can get into a buck hop and skid rolling through a parking lot in 2nd gear just off idle but have gotten much better at anticipating for this and staying out of it.
