05lly2500hd
Recruit
- Messages
- 67
- Reaction score
- 0
tires were dragging on left turns, so I pulled off the rear diff. cover to look.
Pinion and ring seem fine, there are 4 gears inside the "carrier" (not sure of proper terms) the gear on the driver's side axle has another gear behind it with many maybe even hundreds of smaller "grooves"....that piece is cracked in several spots and many teeth broken off. What is this piece and where can i get it and can I replace it myself?? Please help asap!!! Thanks!!
