Dunedain15
Active Member
Yet another tale of woe. About a month ago, my wife was driving the Burb. She was accelerating up a hill from a stop, and the truck just shut off. She pulled to the side of the road, and it fired right back up as if nothing were wrong. She started driving again. About a half mile down the road she came to a stoplight. When it turned green, she stepped on the gas, and it accelerated as normal for a couple seconds then shut off again. Again, it fired right back up. Haven't had a single problem with the truck since.
Fast forward to last night. Driving home from a beer run, I accelerated from a stoplight. Accelerated normally for a couple seconds then died. Fired right back up as if nothing were wrong. Made it home with no other issues.
I got a new Stanadyne PMD, heatsink and extension cable from Leroy in March of last year, and it's currently mounted behind the front bumper. Physically, everything looks fine in that area. The PMD that was on the truck when I bought it was a black one that was zip tied to a hunk of aluminum and bolted to the intake manifold. That one never had an issue, but I wanted to replace it because it was zip tied to a heatsink with no heat transfer pad. I replaced the lift pump with Leroy's pump/filter kit in August of last year. I have not dropped the tank to remove the sock yet. The Burb has 157,000 miles on it, and AFAIK, it's the original injection pump. I have a fuel pressure gauge, but the GlowShift sending unit is dead again (2nd one in a year), so I don't know what the pre-injection-pump pressure was when it died.
I said all that to ask two questions:
Is there a sending unit I can get from somewhere else that will work with the GlowShift gauge?
The problem is super-sporadic which is frustrating. So, where do I start troubleshooting?
