The smaller pipe would only be advantageous on intial spooling, less volume to pressurize, but the engine under load will reach and maintain the same peak pressure once the larger pipe is pressurized behind the turbo. The larger pipe would likely help with less backpressure under the no and low load scenarios though. And even though they can pressurize to the same level, you can have more flow at load with the larger pipe at the same pressure. The choke point is the same, or adjustable with wastegate, but fluid dynamics is not a weakest link in the chain kind of equation.
