toytruckman
EGR solenoid not working. Thats ok I dont care but it's got the CEL on.
How do I disable that so I can clear the CEL?
Thanks
dave
Thanks
dave
Thanks,
But I have EFI Live and I found how to disable it. Problem now is if I dont block it right away how do I know what position it's in, I dont want it open any.
You can actually remove the actuator/motor from the egr valve if you disabled it through EFI. There are four philips head screws that hold it on. Take the screws out, unplug the motor and remove it.
People say that there's enough pressure on the exhaust side to push the valve open, but I don't believe it. Once the motor is off the EGR valve, take a screwdriver or something similar and push on the valve. It's held closed with a fairly stout spring that takes a lot of pressure to overcome.
I'll find a photo of the EGR valve so you know what I'm referring to.
Here it is. The EGR valve is the cast iron piece with two rectangular ports. The intake and grid heater assembly has been removed in this photo. The actuator is the black plastic thing to the left held on with screws.
