havns3
friction lover
i recently bought a ford dually to pull camper. it came with a brake controller and it is hooked up under dash to factory plug. from what i have read that is a factory towing option. in the rear i have to add the 7 blade connector. i have the tee connector that plugs in for the lights. There are two more factory plugs hanging down one has two wires going to it and one has three wires. is this the ford factory tow package for the brake controller and do you have to buy the plugs for them to connect to the trailer connecter from ford? it looks like who ever had the truck before took the trailer adapter and the connectors that where attached but left the four wire plug connector
i have almost decideed just to run new wiring for the brake controller and the trailer battery power. but would like to use the factory option if possible.
