DZZ71
"Living The 6.5 Dream"
Well im about to start my second build, I thought i would share what im doing with the engine and my modifications. Here is the parts.... The Block is a 141 with squirters by the way. Any input and ideas is greatly appreciated. I will be posting lost of pics as the engine comes together over the next 3-4 weeks!
Scat crank shaft
Fluid Damper
Delta 206 Camshaft
New 0.30 over pistions (dished and ceramic coated)
Arp head studs
New Reman heads
Bottem end gurdle/Studs
Ported Heads
Rebuilt IP
HX35 for inital break in then have other plans
Buddy Chip
Water/Meth injection
Heath H.O injectors
Raptor 150GPH Lift Pump (with secondary fule/water filters)
Dual electric fans
Upgraded Oil lines
Scat crank shaft
Fluid Damper
Delta 206 Camshaft
Arp head studs
New Reman heads
Ported Heads
Rebuilt IP
Buddy Chip
Heath H.O injectors
Dual electric fans
Upgraded Oil lines
